Flat Tappet Motor Oil
#1008016
06/06/11 07:08 PM
06/06/11 07:08 PM
Posts: 127 Missoula, Montana
ChadP
Missoula, Montana
I'm sure this has been talked about before...but what oil are you using for big blocks? High zinc, added Molly - what brand do you like?
'65 Coronet 500
Re: Flat Tappet Motor Oil
[Re: Junky]
#1008021
06/07/11 01:05 PM
06/07/11 01:05 PM
Posts: 5,894 Florida
Locomotion
Most oils, including diesel, have been lowering thier zinc content and it's not easy to keep up or find current numbers. They have diesel oil specifically for 2007 & newer diesels with low zinc because zinc doesn't get along well with the newer catalytic converters. Find CURRENT numbers or call the manufacturer. Amsoil has a wide selection of high zinc diesel and car engine oils that offer benefits in addition to their higher zinc content. I use the 5w-20 Dominator in my race car. Amsoil high zinc selection Amsoil source and info.
[Re: babarracuda]
#1008027
06/07/11 08:59 PM
06/07/11 08:59 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I'm currently running the Summit brand racing oil. There's plenty of options these days.
[Re: can.al]
#1008030
06/07/11 10:09 PM
06/07/11 10:09 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
quaker state 10w-40 from walmart
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: ChadP]
#1008032
06/08/11 01:56 PM
06/08/11 01:56 PM
Posts: 79 Finland
CarelianCuda
Finland
Valvoline VR1 Racing Oil 20W-50. Zinc/Phosphorus m%, 0.14/0.13
1970PlymouthCuda383 1970AMCHornet2D232 2003TruckmastersOkenosDurangoSlt+ 2008DodgeChallengerSRT8
[Re: ChadP]
#1008033
06/08/11 02:41 PM
06/08/11 02:41 PM
Posts: 4,848 Memphis
HemiRick
Memphis
Shell Rotella T 15/40 I run it in all my flat tappet cars.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: 70AARcuda]
#1008037
06/09/11 12:04 AM
06/09/11 12:04 AM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
That's what I have been running lately, good ol' Quaker Sludge! I do add a bottle of 'ZDDP Plus' to boost the zinc/phos up. No Fram for me, I run a Wix 51515 from the group buy. Last year I picked up 10 - 5gal jugs when they were $10, now they are $11.50.
[Re: Ramrod39]
#1008041
06/09/11 09:08 AM
06/09/11 09:08 AM
Posts: 15,487 Florida
scratchnfotraction
OK, what's an EDM lifter?
has a small hole drill in the flat bottom that slides on the cam lobe
it oils the lifter/cam lobe so it rides on a thin film of oil to reduce wear.
[Re: scratchnfotraction]
#1008042
06/09/11 11:04 AM
06/09/11 11:04 AM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
I feel the faster the ramp speed/the higher spring pressures an EDM lifter is cheap insurance. I suppose using them on a purple shaft-type cam could also give someone peace of mind.
