finally installing my 6pak,how do you block heat cross #1006433
06/04/11 10:45 AM
06/04/11 10:45 AM
weymouth,mass.
meepmeep70 Offline OP
weymouth,mass.
over? everything i read says 6pak should have cross over block,so how do i do that? thanks
Re: finally installing my 6pak,how do you block heat cross [Re: meepmeep70] #1006434
06/04/11 10:55 AM
06/04/11 10:55 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Simple. You buy the valley pan without crossover holes. Felpro 1215. http://www.summitracing.com/parts/FEL-1215/?rtype=10
Re: finally installing my 6pak,how do you block heat cross [Re: meepmeep70] #1006435
06/04/11 12:54 PM
06/04/11 12:54 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
What are using for a choke ?
Re: finally installing my 6pak,how do you block heat cross [Re: JohnRR] #1006436
06/04/11 02:37 PM
06/04/11 02:37 PM
weymouth,mass.
weymouth,mass.
john you have a pm
Re: finally installing my 6pak,how do you block heat cross [Re: meepmeep70] #1006437
06/05/11 09:24 AM
06/05/11 09:24 AM
JohnRR Offline
JohnRR  Offline
replied , call you later today
