Small block oil pressure WAY TOO HIGH
#1005637
06/03/11 02:12 AM
06/03/11 02:12 AM
Posts: 3,415 Toronto
mshred
Toronto
Hey guys, Im in another dilemna here...Was doing the last of things to my scamp to get it running finally- adding oil and priming the system. But when I went to go prime it the oil pressure sky rocketed past 150 psi pegging my needle on my gauge! At first I thought it was the gauge, so i tried another that only goes to 100, and it shot way past that one too!! The engine itself is a 91 360LA block. I did full block oiling mods including a ported standard volume meiling pump with a high pressure relief spring, all block passages to 1/2", crossover tube in the lifter gallery, stock pan and pickup tube, and some restrictors in the mains for the cam bearings. Bearings are full groove on the mains, clearances are about .002, using 15W40 Rotella oil on break in and during this prime. The engine is using hydraulic roller lifters I pulled off the oil pan (A giant chore within itself!) and i also had a valve cover off, and all the rockers (hughes rockers) were getting oil. I pulled the pump apart thinking the relief valve may have been getting stuck, so i pulled it apart, cleaned up and made sure it was in the right way, and then put in the standard releif spring for good measure. Instead of putting the pump back in the motor i tried this- I blocked off the side that attaches to the main cap with a bolted on plate tapped for a oil pressure gauge, and then i sucked oil through the pickup while spinning the pump...once again the pump skyrocketed to past 100psi. Im thinking the concept of this test should work since i really didnt want to put the pump back in the car and have this happen to only pull it out again. The pump itself is brand new, was inspected too..Im wondering if there is a right way to reinstall the plug for the spring? Ive been installing it with the dimple facing the outside of the pump. Im thinking of ordering another new oil pump tommorow and testing it the same way i did with this one before i put it in to see what happens, but if it reoccurs, im stumped Does anybody have any suggestions as to what this could be? Sorry if this is long winded, and yes a new pump is the best answer, but now im afraid to take apart a new pump and port it to have this problem again, so id rather use this one if i can...any ideas on what could be going wrong? I feel like my little test helps isolate the problem to just the oil pump itself, but i could be wrong
Re: Small block oil pressure WAY TOO HIGH
[Re: mshred]
#1005638
06/03/11 07:14 AM
06/03/11 07:14 AM
Guitar Jones
So you're testing the pump with just an oil pressure gauge? I don't think that is an accurate way to test it as you've dead headed the pump. The cup for the relief spring should only be pressed in far enough to get the cotter pin in and no further. The high pressure relief spring was your first mistake. The second is that 15w40 oil. With .002 bearing clearance I would use 5w20.
I used a shorter cup plug on my standard oil pump pressure relief spring, it's only about half the depth. Granted I haven't run mine yet but I don't anticipate any problems. It doesn't take much on that spring to change it a good bit.
[Re: Guitar Jones]
#1005639
06/03/11 07:37 AM
06/03/11 07:37 AM
mshred
Toronto
Hey guitar jones, my plan was to effectively dead head the pump like you said...I thought that it would give an idea of what its pumping, but i guess I was wrong. Before i did that though i did test the pump in the motor with it all bolted together (just wanted to make sure that part is clear from my rambling )
As far as oil goes, i was told not to use synthetic, which I have some in 10W30 weight, in order to break in a new engine. I believe that the cup plug in my pump is shorter than what i pulled out as i remember the other one being deeper, but im wondering if i have the cup plug installed the right way? I thought the same thing that if that spring is changed a little it could cause a huge change in pressure. Do you happen to have a picture of of what direction that cup plug deep part should be facing?
The block has the full oiling mods as outlined in your article over on FABO btw
[Re: mshred]
#1005640
06/03/11 08:30 AM
06/03/11 08:30 AM
Guitar Jones
You shouldn't use synthetic for initial break in but a lighter weight oil is better. The cup should face out. After the initial breakin you can change over to synthetic and your oil pressure may come down a little.
[Re: Guitar Jones]
#1005642
06/03/11 02:07 PM
06/03/11 02:07 PM
Posts: 660 San Diego
formula S
San Diego
The cup faces in, opposite of the way you would install a freeze plug. The spring goes inside of the cup
[Re: formula S]
#1005643
06/03/11 02:27 PM
06/03/11 02:27 PM
formula S
San Diego
Here is a link from summit click on the 360 degree view http://www.summitracing.com/parts/MEL-M72HV/?rtype=7
[Re: formula S]
#1005644
06/03/11 03:38 PM
06/03/11 03:38 PM
Guitar Jones
Yeah but that's not the way mine came. Maybe that's the problem
[Re: Guitar Jones]
#1005645
06/03/11 05:28 PM
06/03/11 05:28 PM
Posts: 1,708 S. Il. U.S.A.
5spdcuda
S. Il. U.S.A.
Since it's been awhile since I had one apart I decided to go out to the shop and look at an old untouched factory pump. The cup faces out [ opposite of a freeze plug ], and in just deep enough to clear the cotter pin. Since the cup plug is roughly 1/4 in. deep if you were to reverse it, it would result in a considerable increase in spring pressure. FWIW my 360 holds 65 psi hot at 2000 rpm with either 15w40 Rotella or 20w50 Bradpenn and about 5 psi less with 10w30 Bradpenn. This is with drilled oil galleries and full groove mains and a Speed Pro HV pump with a MP high pressure spring. Unbushed lifter bores with Hyd. flat tappet. I just realized that there may be some confusion as to what is meant by cup facing in or out. I think of it as out since that's where the bottom of the cup is.
[Re: 5spdcuda]
#1005647
06/03/11 09:15 PM
06/03/11 09:15 PM
Guitar Jones
I have a Procomp knock off in the garage I just went and dug out, it's got the cup facing in towards the spring like the Summit picture. I know my Melling did not come that way so this looks like the likely cause. I guess I'll be pulling the pan back off mine. Better now than in the car.
[Re: Guitar Jones]
#1005649
06/03/11 11:51 PM
06/03/11 11:51 PM
Posts: 892 USA
krw71ragtop
USA
I just primed my motor last week. 75' LA 360 with the crossover tube oil mod. I primed the pump in a vice with a drill (75-80 lbs), installed pump, then I primed the motor with a drill. screwed a oil preasure guage right in the sending unit hole first, and left the intake manifold off to make sure no leaks at the crossover tube. Also had someone turning the crank too while priming. The melling oil pump I used had the plug with the cup part facing the spring. I'm using Brad Pen 15w40 oil and had between 75-80lbs of preasure. Make sure the plug is against the cotter key as mentioned, because the deeper the plug goes in, the more oil preasure you will have. Usually the spring won't push the plug back out against the cotter key. I'll post a picture of the pump the way it came new. If you prime the pump in a vice and don't have enough preasure you can drive the plug in deeper and install washers between the cotter key and the plug to bump it up. I do 1 washer at a time until I get the preasure I want. I'll post a picture of an oil filter that had too much preasure in my 416". If you think it's bad removing a stock oil pan while motor is in the car, try removing a Milodon oil pan with headers! Keep us posted on your findings. Mine is a 410" stroker, with Hughes 1.6 roller tip rocker arms, EDM oil through solid lifters , Hughes push rods, Eddy heads ported by Ryanj, 10.8-1 SRP pistons, Eagle crank and H-beam rods. 540 lift Comp cam, and melling gear drive timing set. Going in a 74' Scamp.
[Re: Triple Threat]
#1005653
06/04/11 09:37 AM
06/04/11 09:37 AM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
Just went and grabbed my new Melling HV pump out of the box.
my question is the picture u posted,is that the way the cup should be,or is that the wrong way? mr triple
[Re: fishy340]
#1005654
06/04/11 12:34 PM
06/04/11 12:34 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
That picture is the correct way. The flat face of the cup is against the cotter pin. The recess in the cup is for the spring to sit inside. If its switched around, your gonna have a lot of pressure against the relief spring.
If you take these pumps apart, be carefull about what you " hone". Dwyane and I were just talking about a problem where someone did this and created a big issue by making a very small mistake while honing out pump passages.
Debur them, chamfer them, clean them and run them.
Pic on left is new HV, on right STD pump.
RIP Monte Smith
