Re: HELP!!!! 383 Clattering????? [Re: Kern Dog] #1005130
06/03/11 01:41 PM
06/03/11 01:41 PM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
It as all new every thing. New rockers in the right spots with new hold down bars. All new motor mounts. I think there is a couple of the lifters just not working right. I'm going to check with the vac. unhooked and replace the 2 lifters and see if that maybe will fix it. The clattering when it does it sounds just like some bad gas but it isn't, it has fresh gas in it. Ronnie
Re: HELP!!!! 383 Clattering????? [Re: okie] #1005131
06/03/11 03:02 PM
06/03/11 03:02 PM
ill
dennismopar73 Offline
ill
i have seen bad new lifters before, been more common lately,??
Re: HELP!!!! 383 Clattering????? [Re: okie] #1005132
06/03/11 05:03 PM
06/03/11 05:03 PM
Sebring, Florida
Mopar Grandpa Offline
Sebring, Florida
You do realize that you can change the lifters without pulling the intake manifold?
Re: HELP!!!! 383 Clattering????? [Re: Mopar Grandpa] #1005133
06/03/11 05:39 PM
06/03/11 05:39 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
How the heck is THAT possible?
Re: HELP!!!! 383 Clattering????? [Re: Kern Dog] #1005134
06/03/11 05:44 PM
06/03/11 05:44 PM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
"That's what I'd like to know about it".....Seinfeld show, my favorite!
Re: HELP!!!! 383 Clattering????? [Re: Kern Dog] #1005135
06/03/11 05:50 PM
06/03/11 05:50 PM
USA
BB Dart 69 Offline
BB Dart 69  Offline
USA
Try a qt of tranny fluid in the oil, might free up the lifter. Old school
Re: HELP!!!! 383 Clattering????? [Re: Kern Dog] #1005136
06/03/11 06:20 PM
06/03/11 06:20 PM
Sebring, Florida
Sebring, Florida
And I thought most of you guys were as old as I am....obviously not. Here's how it's done and trust me I done it a bizillion times.
Remove the rocker and push rods assembly from the heads. Take a telescoping round magnet down thru the push rod holes in the head and pick up the old lifter, pulling it up thru the same area, obviously. You install the new lifter the same way. Works every time providing you aren't using alum. heads with small push rod holes.
Re: HELP!!!! 383 Clattering????? [Re: Mopar Grandpa] #1005137
06/03/11 09:35 PM
06/03/11 09:35 PM
scratchnfotraction Offline
they make a lifter removal tool also,it has a pull trigger to spred the end to catch the lip/plunger retainer to lift the lifter out and install it the same way.
kinda like the 3 finger picker upper flex tool
dont know about being old,but i know how its done
Re: HELP!!!! 383 Clattering????? [Re: scratchnfotraction] #1005138
06/03/11 09:40 PM
06/03/11 09:40 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
You can easily get them out of distrib hole with some trickery. We did them on the small block chevs too.
