Re: 904 builders/racers... advice needed (long)
[Re: 340_Dart]
#1004716
06/01/11 10:37 PM
06/01/11 10:37 PM
Posts: 492 South Jersey, NJ
DragDart360
South Jersey, NJ
Would it not be less expensive to upgrade the engine than the trans? What are the engine specs?
70 Dart Swinger, 2850 lbs SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
[Re: 340_Dart]
#1004718
06/01/11 11:07 PM
06/01/11 11:07 PM
Posts: 2,408 Ambridge, Pa.
rickraw
Ambridge, Pa.
i'm running a, i think it's a 1971 904. 440 sb, 9.69@138.50. according to a&a, drum isn't a problem. billet low rev servo, red alto plates, harden strut, use teflon seal rings on support. line pressure is critical. should hold up with 180#, since 904 plates have a smaller surface area than a 727. i have a low 1st gear, 60'-1.30. stay safe, seeya.
[Re: rickraw]
#1004721
06/01/11 11:54 PM
06/01/11 11:54 PM
Posts: 1,745 Maryland
340_Dart
Maryland
I'm not saying the combination on the motor is perfect, but I doubt there's anything I can do to pick up .2 for the price of builiding a 904.
408 bottom end, steel k1 crank, k1 rods, diamond flat top pistons, factory block Indy 360-2 cnc heads, Indy intake converted to dominator flange. 1050 dominator 262,268@ .050 solid roller. .698 lift 10.3:1 compression. Pump gas motor
3000# race weight valiant 4.56 gear, 29.5x10.5 slick, ladder bar car 727 with transbrake, 5400 converter The only thing I think that would pick the car up would be to increase compression to 11-11.5 compression. However, with the Indy moved exhaust valve, there is no radial clearance on the exhaust valve relief...
[Re: DavidDean]
#1004722
06/02/11 12:06 AM
06/02/11 12:06 AM
dartman366
Mt. Vernon, Ohio
I also replace all the bushings and thrust washers, multi spring retainer as shown before, and I buy my kit's from Mancini, MRE 006 has the blue plates and kolene steel also a kevlar intermediate band (don't use it with a aluminum drum)use the 999 high gear drun and you will have to have the back of the pump machined for clearance, reenforced band strut and do the oiling mod's that I believe are in the tech section or the archives,, and also keep the line pressure up if you use the TA valve body it has only about 125# of line pressure, need to get that up around 150# or a little more, A@A has a spring you can replace on the VB that will up the pressure and greatly improve the action of the VB and clamps the clutches harder.
[Re: 340_Dart]
#1004724
06/02/11 02:47 AM
06/02/11 02:47 AM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
Just use an early trans, so you don't have to deal with the lock up stuff which HP parts are limitied. You don't need the bigger drum from the 999. You can buy thinner discs and run 5 in the 904 drum. You will also need a shim kit to get proper clearance. And mixing parts is a PITA. Don't deal with that headache. Put good bands, clutches, and steels in. Get a Valve body from A&A, rebuild the trans, put in a blocker rod and put in a billet piston and 4.2 lever. I have nothing else done to my trans and I'm running it with a 7100 stall. 878 hp 563 tq... No trans brake though, so Rick may be able to recommend what else you HAVE to do. I have less than $800 in my trans besides the trick custom valve body Rick built me. I have 37 1/8 mile passes and 52 street miles on it. No issues and the oil pan shows no problems... Just my
[Re: dOc !]
#1004726
06/02/11 06:40 AM
06/02/11 06:40 AM
Posts: 20,662 in a cattle trailer down by th...
Guitar Jones
Everything that needs to be said has already been said but I don't think you'll see 2 tenths, especially without the low gear. I think you'll be lucky to see .08.
[Re: S/ST 3040]
#1004729
06/02/11 07:21 AM
06/02/11 07:21 AM
Guitar Jones
904 is 27 lbs lighter with 17 lbs of it rotating. Call Rick Allison at A&A.
4.56 gear and 29.5" tire?! Woohoo!
Yeah I know. I think they are worth more behind a small cube low torque engine, especially with the low gear set. Behind a large cube small block not so much. I know two guys, both big blocks, one is a Super Stock car and the other a Stocker. Both of them bought the high dollar ProTrans units and they didn't see but .15 at best and that could have been the weather.
I have a 904 in my car with the low gear but I went from a 4 speed to the 904 mainly because of the weight. Now I can tell you the low gear set really woke my car up when it was a 340 cube engine.
[Re: S/ST 3040]
#1004730
06/02/11 07:49 AM
06/02/11 07:49 AM
340_Dart
Maryland
Alright Vic, I gotta ask, what's the comment mean? Too much gear?
[Re: 340_Dart]
#1004731
06/02/11 10:18 AM
06/02/11 10:18 AM
Posts: 6,149 Melbourne , Australia
LA360
Big HP 904 I would run a 5.0 lever, but a 4.2 is the next best thing. 904's need the clamping force. 904's will break input shafts from time to time, but I would only worry about it when you actually break one.
Alan Jones
[Re: 340_Dart]
#1004732
06/02/11 01:18 PM
06/02/11 01:18 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
I think it's a little much but, at 131.5 MPH, you are probably less than 7200 RPM. I know Bill Hart runs the same tire and gear and Lonnie used to run 4.88's with 32" tire.
I guess I really can't point any fingers in the tire/gear department.
You definetly won't need the 2:74 1st gear! I don't.
[Re: S/ST 3040]
#1004733
06/02/11 04:18 PM
06/02/11 04:18 PM
Guitar Jones
I had 5.13's with a 29.5 tire with a 340. Shifted at 8000 went through the lights at 8100. But I had W5 heads too.
[Re: S/ST 3040]
#1004734
06/02/11 10:07 PM
06/02/11 10:07 PM
dartman366
Mt. Vernon, Ohio
mine actually went quicker with the standard 2.45 1st gear, unless you are way heavy and low horsepower then don't waste your time with it.
