Blocked exhaust crossover.... Pros? Cons? #1002974
05/30/11 02:16 PM
05/30/11 02:16 PM
Medford OR
FrankenScamp Offline OP
Medford OR
Fill me in. I blocked mine in an attempt to keep heat away from my eddy carb. I've heard it can cure off idle stumble also.
This might sound silly but it seems to have changed the sound of my exhaust also. Is that right?
Just looking to learn all the reasons people block it out.
Re: Blocked exhaust crossover.... Pros? Cons? [Re: FrankenScamp] #1002975
05/30/11 02:24 PM
05/30/11 02:24 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
No more burned intake manifold paint!!!
1MYTGTX
Re: Blocked exhaust crossover.... Pros? Cons? [Re: 1MYTGTX] #1002976
05/30/11 02:29 PM
05/30/11 02:29 PM
Medford OR
Medford OR
always a plus!.....mine is bare aluminum.
Re: Blocked exhaust crossover.... Pros? Cons? [Re: FrankenScamp] #1002977
05/30/11 02:30 PM
05/30/11 02:30 PM
I've always blocked them off.
Cooler intake charge is the main reason.
Never had a problem with running motors that way on the street?
Re: Blocked exhaust crossover.... Pros? Cons? #1002978
05/30/11 08:40 PM
05/30/11 08:40 PM
scratchnfotraction Offline
i do it to keep the heat soak down on alum intakes with alum carbs
yes it will make the exhast note a tad different
aftyer a 40 mile drive I can not keep hands on the intake anywhere but the carb is like warm
cross over blocked,1" stacked alum plate/gasket heat disapater on mine
cured all the hot start problems,and the fuel perking stop
yes,it is for a much cooler intake charge,cooler denser air charge = more HP and is/was the main reason its done,now it mainly for heat soak on a daily driver
had a old timer tell me it was to replace the H pipe found on the mid 60s to late 70s exhast systems.
evens out the exhast pulse like the H pipe does.
now if that is true or not I have no idea,sound good though
Re: Blocked exhaust crossover.... Pros? Cons? [Re: FrankenScamp] #1002979
05/30/11 09:45 PM
05/30/11 09:45 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I have had an icing incident or two with mine over the years. When the temp and humidity is just right, it will ice up and be a pain. If it does ice up, the best thing to do is to shut it off long enough for the heads to heat the intake and carb enough to defrost them.
That's the only downside I have ever seen.
Master, again and still
Re: Blocked exhaust crossover.... Pros? Cons? [Re: DaveRS23] #1002980
05/30/11 10:20 PM
05/30/11 10:20 PM
Under My Car
Mopar_Country Offline
Under My Car
I blocked mine and the base of my carb is around 68* when the engine is warmed up. I never checked it before but I can only imagine it was hotter than that.
Re: Blocked exhaust crossover.... Pros? Cons? [Re: Mopar_Country] #1002981
05/30/11 10:38 PM
05/30/11 10:38 PM
Florida STAYcation
BeEtLeJuIcE ! Offline
The village idiot's idiot
Florida STAYcation
A engines with 2 bbls are FAMOUS for blocking the crossover ON ITS OWN. Not a good deal at all.
I say on anything that is a street car .. you want to "heat" in the intake to eNhance A/F atomization.
Re: Blocked exhaust crossover.... Pros? Cons? [Re: FrankenScamp] #1002982
05/31/11 07:34 AM
05/31/11 07:34 AM
PA
BTTG Offline
BTTG  Offline
PA
What's the consequence of blocking if you are running a carter with the choke winding in the manifold? slower opening or no opening? how much air actually will flow back through the manifold once the heat riser valve is open.....or if the valve is not in place? assume the path of least resistance is down the passengers exhaust bank.
Re: Blocked exhaust crossover.... Pros? Cons? [Re: BTTG] #1002983
05/31/11 09:21 AM
05/31/11 09:21 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
For a street car that gets driven all the time and it is a colder area then it is a good idea. It helps driveability alot for that. It heats the intake to heat the incoming fuel-air mixture which helps alot in cold weather and it heats the choke well in the intake to heat the choke coil in that style intake. But most of us gearheads (me included) that drive our hot rods in the warmer months we dont want it. We want the cool incoming air charge as it is more dense and a cool fuel-air make more hp as it is heavier and will fill the cylinders more. And as most high performance cars can have heat soak trouble in warm temps it will make that worse in warm temps. So most muscle cars dont really need it unless its a year round driver.
Re: Blocked exhaust crossover.... Pros? Cons? [Re: 383man] #1002984
06/01/11 06:50 AM
06/01/11 06:50 AM
Palmyra, NY
63stabamatic Offline
Palmyra, NY
On my 69GTX I had to unblock mine to make the stock Carter AVS choke open correctly. It gets hotter but doesn't seem to make the fuel perk problem any worse though. As was mentioned exhaust would sometime block the crossover causing the choke to close, made for some bad starting on warm engines. Back in 1970 My cousins 1970 Swinger with a 340 had that problem.
Re: Blocked exhaust crossover.... Pros? Cons? [Re: 63stabamatic] #1002985
06/01/11 07:35 AM
06/01/11 07:35 AM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
When I went back to the stock cast iron manifold & correct Carter carb, I still bought the blocked off valley tray but on the choke well side, I drilled a few 1/4" holes to let a little heat in to aid the choke operation
1MYTGTX
Re: Blocked exhaust crossover.... Pros? Cons? [Re: BeEtLeJuIcE !] #1002986
06/01/11 06:17 PM
06/01/11 06:17 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
I tried blocking the crossover on my mild 440 in an attempt to cure the heat-soak issues. The exhaust got a resonance from 2000-2300 rpm that was so loud and so annoying that I immediately headed back to the garage and opened the crossover. The resonance came on/off like a light switch.
I have an X-pipe, so that may exacerbate the problem, but I have large Dynomax SuperTurbos so it's not real noisy to begin with. YMMV.
