holley 750 help
#1002640
05/30/11 02:13 AM
05/30/11 02:13 AM
Posts: 1,390 CA.
RAY1969CARS
CA.
CAN YOU FIX A BROKEN booster ???? AND DOZ IT HAVE TO B A 750 ONE OR CAN IT COME OUT OF A 650 ??? PLUS WHERE DO I GET ONE ?? can i buy just one ?
part two
PROFROM MAIN BODY ??? WHAT WOULD THE JETS BE ?? WAS A 4779-7 2679 I GOT IT USE NO JETS WHAT WOULD I USE ON A 340 ???
Re: holley 750 help
[Re: MR_P_BODY]
#1002642
05/30/11 09:35 AM
05/30/11 09:35 AM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
You will need to get a tool for installing boosters, its not cheap, by the time you buy the tool & the boosters you'll be out more then a new Proform mainbody, i'd just junk that one or use it as a paper weight. The Proform mainbody is really nice, it comes with jets/gaskets/base screws & extra air bleeds if your useing 4 corner idle, plus instructions for the adverage hobbiest. Just stay away from the "knockoff" on e-bay, its cheap, but i wouldn't trust it. Here ya go. The PF is 20.00 cheaper then the Holley. http://www.jegs.com/i/Proform/778/67100C/10002/-1http://www.jegs.com/i/Holley/510/134-300C/10002/-1
Re: holley 750 help
[Re: RAY1969CARS]
#1002643
05/30/11 09:41 AM
05/30/11 09:41 AM
Posts: 622 NC
chris3
NC
The best place to start with the jetting is with the jets in the list that was attached. Work up in steps of two. When the car drops off back up one and you should be good.
Are you sure the booster is broken or is it what some of us call the "snubby" booster. There are boosters made with and without the brass tips on them. We run the boosters with the brass extensions with the larger pumps on our 340 Duster. I have an old Holley book, which has been out of print for a number of years, and I will look to see what booster numbers were in the 750.
To remove and change the booster you need a large phillips screw driver to remove the center screw. This screw has a tapered seat. When you remove the booster there is a small gasket. With the booster removed, don't hit the accelerator. There is a small needle under the booster and it will be pushed out by the accelerator. I will add some photo before the day is over.
Re: holley 750 help
[Re: chris3]
#1002646
05/30/11 03:41 PM
05/30/11 03:41 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
I am sorry, I just realized that the "booster" on the right side is broken off. I went out to the shop and took pictures of the "squirters" and when photographing the top of the carb I went back and looked closer at his photo.
The information concerning replacing the "booster" is correct. It is a task and replacing the body will be much simplier.
I see the booster thats broke is the one on the stock holley main body if any of you guys have a main body for sale im a buyer !!
Re: holley 750 help
[Re: RAY1969CARS]
#1002650
06/01/11 01:18 AM
06/01/11 01:18 AM
Posts: 52,972 Romeo MI
MR_P_BODY
what is the end # what doz it refer to ????
4779-(?) 4779-1 4779-2 4779-3
Latest version of that carb(usually a correction or up-date)
Re: holley 750 help
[Re: MR_P_BODY]
#1002651
06/01/11 01:24 AM
06/01/11 01:24 AM
Posts: 1,390 CA.
RAY1969CARS
CA.
thanks
