which windshied trim clip is correct. 68 road runner #1000245
05/26/11 02:39 PM
05/26/11 02:39 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
There are 2 types available. Which one of these is right?
Re: which windshied trim clip is correct. 68 road runner [Re: Kam*Kuda] #1000246
05/26/11 02:56 PM
05/26/11 02:56 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Had the same issue with my 68 Roadrunner. I bought the 68-70 clips from a vendor and they had the short clips.
The old clips from the car were the long ones. I called Jamie at Mega parts, and he told me that a lot of 68 use the long clip, normally found on 66-67 cars.
I reorded the clips and used the long ones, they were correct for my car.
Re: which windshied trim clip is correct. 68 road runner [Re: sthemi] #1000247
05/26/11 10:55 PM
05/26/11 10:55 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
It looks like the long ones are correct?
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: which windshied trim clip is correct. 68 road runner [Re: Kam*Kuda] #1000248
05/27/11 01:09 AM
05/27/11 01:09 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
The long ones look correct on your car. To use the short ones the holes would need to be drilled closer to the edge.
Try putting the window gasket in and see where the clips wind up to be sure.
