Lip orientation
The lip on the rear main seal should point toward the crankshaft and not towards the back of the engine. The lip on the seal is designed to allow oil pressure to force the seal against the crankshaft, improving its sealing capability. When the seal is pointed the wrong way, it allows oil pressure to force oil past the seal, resulting in a leak
