I'm looking to purchase a plasma cutter. I would like to be able to cut anything from sheet metal up to 5/8" steel plate without issue. I'd like to find a unit that runs on 220V single phase power, is highly reliable and won't break the bank when purchasing consumables (tips, etc.).
Does anyone here use a plasma cutter for these purposes? If so, what are you using and how happy are you with your choice?
