Ever since I have had my 71 charger the Key Cylinder would come out if you pulled on it. I took a deeper look at this problem today and think maybe the cylinder i have might be for a different model. The little spring loaded lock retainer seems to be in a different place on the cylinder then it should be. Am thinking i may need to buy a correct one but want to verify first.
