Quote: Oh and what's really bad about doing that is; you see those yellow paint marks on the tires well that's marked by the tire manufacture to indicate the lightest point on the tire so that the (yellow mark) gets positioned at the tire valve which is the heaviest position on the wheel to minimize the amount of weight that might need to be added to balance the wheel and tire.....now if you think that's not a cost savings for an automobile manufacture think of 1969 Road Runners that they made over 80,000 of them times (X) 4-wheels per car and if it saved just one weight per car..............I'd like to have the coin saved for 80,000 lead weights MikeR
THANKS for the nugget of info. I was unaware of the significance of the yellow marking!
