Cool .... have you tried REALLY leaning-it-out ? ....what is the range of the AF #'s ?
I have tried leaning it out a bit. I am currently at 14.1 idle AFR, 14.9 cruise and 12.9 WOT. I know those do not seem that crazy lean but these are dramatically leaner numbers than I was able to get with the carb. If I go much leaner at idle or cruise the car begins to surge I think we have found the sweet spot. I think these are pretty good numbers for an 11:1 big block.
