I think Mopar #7176 is ATF +3. It has friction modifiers to prevent lockup clutch shudder.
You could use the newer ATF +4, I think it is semi-synthetic? (but more expensive.)
I don't think that the +3 is available anymore pretty sure +4 is the preferred fluid , like it or not .
