Yea I think if I just do the water pump and crank they'll be centered enough in the car so it will stay going straight... Oh crap I have a chrome alternator now it's gonna pull left because the right side is gonna be trying to go faster than the left. hahhahahah
Install a goofy foot gas pedal. That will even the left/right power ratio. If you need a little more on the left once you install the pedal, they do make a goofy foot high-low beam switch button cover. This should do the trick.
I’m listening.
