Thank you guys, I went out to check the ratio and when one side turns clockwise I can see the other side turning the opposite direction. Also, turning the wheel one revolution, makes the driveshat spin around two times. So that means I have an open diff, either 3:91 or 4:10 (:11) ?? I was told on open diffs you double the driveshaft rotation to obtain the ratio. Does this sound correct? Thanks again in advance for anyone that can reply!
