Does anybody know if the flywheel 440source sells here
http://store.440source.com/1045-Billet-Steel-Flywheel-New/productinfo/113-1014/works on a 360 LA cast crank motor with external balance? I have the flywheel already from a previous build, and it came with a bolt on weight for external balance, or take the weight off for neutral balance. In their description it says that it works for both big and small blocks, and when I asked 440source they said it should work with the weight they provided, however, i have heard conflicting info since the balance weights of 440's and 360's are different...however, this link makes me think it should work since they list 440 cast 6 bolts and the 360LA cast crank flywheels as the same
http://www.americanpowertrain.com/Mopar/transmissions/flywheel.htmlHas anybody tried this to know for sure? I really don't have the money to buy another flywheel right now, and didnt even think this would be an issue
