1: I have a really hard pedal if I pump my brake more than once. Would this be caused by a bad MC? no
I have a new MC which I will bench bleed and install because of the leak, I just want to be sure to check for any other problem while I'm there.
The new M/C will need to b installed no matter what & it will not hinder your diagnosing so I'd go ahead & do that. (abnormally) hard pedal is from bad booster or a blockage so I'd suspect the line lock
