They work I get 1/2 to 3/4 full between oil changes. The bottom can be hard to unscrew depending on where its mounted, I was thinking of adding a drain valve in the bottom to drain at time of changing oil instead of unscrewing it every time.
I have one that uses a petcock (like a radiator) on the bottom....not a Challenger, but you get the idea.
Oz - could you post a pic of the other end? Wondering where you tied into and I don't want to go through 89 pages to find it. Thanks man
So lazy....
How is this angle ?
