The metal center pin serves both functions, it drops into a "divot" in the plastic shoe to activate the BU lights and in Neutral and Park it makes contact with the exposed metal base in the shoe to ground the starter relay.
The only reason the plastic plunger is spring-loaded is to keep it in contact with the plastic shoe.
