If you have a 12V Ign source feeding into the heater control can you test the circuit that turns the "heat" or "a/c" on and see if either is working? From what you typed the answer to my question is "no". That said, if you turn on the "heat" or "a/c" does the blower motor function? If no I'd guess that you have something wrong with the heater control or 12V is applied to the incorrect terminal. Can you supply a copy of the wiring diagram? That would be very helpful. Please don't make me get up and walk across the living room.
If I turn the controls to either heat or A/C the vacuum operated controls work, but the fan doesn't turn on.
I need to find the wiring diagram so I can start jumping some things around.. Anyone have one postable?
Thanks, -Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah
71 valiant scamp 318/A833OD/AC/PS
00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process
73 W200 Power wagon, PTO winch, 4 spd
