I was wondering how much clearance you should have betwen the oil pan and the centerlink on a 70 Barracuda with a 440? Is there a difference with the cross member 440/HEMI vs NON 440/HEMI cross member move the engine higher or shift it some way? Is there a center link/pitman arm diffrence between a base model and the Performace BB versions? My car is a clone and I am currently running solid mounts and is a manual transmission.
