i have a 68 satellite with a drum brake booster,single diaphram.
will the dual diaphram booster,to suit factory disc/drum,bolt up without any modification ?
thanks,
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm
Power by Tex's Automotive
