No engine to battery ground,Battery is in the trunk(grounded to a frame rail) will pull the ground of the K and relocate it to the body...Auto Zone said my battery was good(5+years old and sitting)its good for about 2 minutes of cranking(starter seems to be at speed) so either the battery is no good or another problem has shown itself,i want to implement the timing suggestions but need some steady juice.
