i have a small block v8 bellhousing from a van. has the window with the timing marks on it. also has the bellhousing mounted ball.
i am doing a bit of gathering for a 4 seed sap into a 67 b body. will this bellhousing work for me on this swap?
trying to bolt a a833 4 gear on this motor and ran into this issue. just wondering if its worth my time at this point to use this part or search for another.
steve-o
if You Like Gremlinsteve. Gremlinsteve Likes You.
