I'm running into the same problem right now. Doing my 70 Challenger, the Moog kit came with one washer and the fit seems to be too tight to use it. So, Should I just use the foam washers only and then tighten to spec? A12, did you get thinner shims?
Joe
65 Barracuda
70 Challenger
