Yes he was told that it had never been worked on. As for being apart I dont know what it would they did, crank & bore all std. That cccd on the side had me really stumped. Another thing I talked him into pulling heads while the engine was out for cleanup and paint and found some scratches in 3 cylinders, pulled those pistons to find broken rings. This car has sat for 10 years at one time and 15 for another with out moving. It has machined pad on right side at pan rail but no numbers. I will check back and bell housing flange.
Thanks for info
