Is it coming out of the seal area or in front of it? ...Oh yeah, one other thing... make sure the vent for the axle is not plugged...
With the old yoke in place the gear lube was coming out from the pinion seal...basically the lube would leak out and get tossed out from behind the yoke dust-shield. Nothing was leaking through pinion nut-washer area.
Seeing the responses so far I'm thinking the old yoke was just too worn out...I'll try to measure the wear tonight and compare to the seal shaft specs.
Thanks guys!
