you might be able to pull 12's.
to the original poster...its obvious as stated several times already your are NOT limited to 12's using an AFB style carb, with some tuning abilities you can easily make them run fine and make good power...dont let the guys who say you cant do it decide for you...just because they cant do it doesnt mean everyone else cant
didn't say you couldn't. but you'd have to spens big big dollars on an AFB to equal the performance of an off the shelf 750HP carb. The AFB mentioned above is far from a shelf unit. If rules allowed it he'd probably run a holley. It's just a better design PERIOD. So for the evryday Joe Smoe weekend warrior a holley is a much better choice for all out performance. I've run plenty of Carter and cater based carbs, No issues w/ any, you just get more form a holley.
OP asked "how fast in the 1/4 with a single afb style carb"....your answer " 12's "...not once was it limited to "box stock" or "price"....you said maybe 12's, your WRONG period !
You Thinking It's So Doesn't Make It a Fact
