at the moment just looking at the fuel pumps to the switch panel as it being a race car batt's in the trunk, pumps in the rear, there is no motor so the up frt wiring has to wait.btw using arc panel if that helps
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
