MT, Hooser, and Goodyear all have some decent choices for your combo.
I prefer MT, With your mild combo and 4.10 gear Id go with 9 x 28 MT 3054,s They actually have a 27.3 " diameter that will give you a little more gearing for your RR. With the 4.10,s the max diameter slick that Id go with is around 29"
Id stick with the 28" diameters myself for your ride. The 9 x 28 MT will work great with alot of mild combos. No need to go bigger if you dont need it.
Need your rear end checked out? Contact Grizzly!!
