If the 318 isn't going to be turning high rpm's (4000+) regularly, the extra compression from the stock 318 heads may help with torque for street use (and the smaller valves will not hurt). I'd guess the 318 heads (with resulting higher compression) would make for more torque and a harder launch on the street. If the J's are all you have, run them.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
