Okay, on the ignition switch itself, all the terminals are marked. There are posts marked "ignition 1" and "ignition 2". I am assuming one of these is start position, the other the run position? Is that true, and if so, which is which..I can trace that wire under the dash and to the resistor. I have checked the new harness over and over, and its wired correctly. Starter works fine, so assuming the relay is still good, all wires look good. Ideas?
