All body panels were AMD. He actually recommends AMD and would only ship Goodmark if I specified.
All parts were for a 74 Barracuda. I ended up buying things like the gas tank, sending unit, firewall gasket set, trunk gasket, both quarter skins, both trunk drop-offs, both outer wheel housings, trunk gutter, gas tank supports, complete set of steel brake lines and gas line, t-handle for the trans,...he pretty much had everything I needed, so it was one easy order for me. I got everything in two shipments, metal in one and the other parts in another. I dealt with Chris. Good business Guy.
