cool lobe is over-rated it's better to have a good running engine. Buddy took your basic combo in a 68 charger, added summit 488 cam, headers, t-chain, MP electronic ing, DP4B intake (I think) stuck w/ the Cater carb and the car ran 14.10 driving like grandma. it will work with mani's. You could also look at the mopar 528 solid, although it would like a little more gear.
i'm thinking i can have both a good running engine and a cool lopey idle.
not really. Usually cams that lope have a 106-108 centerline and are designed for racing and they will run TERRIBLE in a non-performace engine. They also pull terrible vacuum so good luck tuning the carb just right. What you want is a sound that is chrisp under WOT. If you want the car to shake turn the idle down.
