is there any tricks in replacing the inner axle seal on a 68'dodge coronet with a 8.75 rear end. i replaced the seal on the driver's side during the restoration of my car, it has been about 4years however the car only has about 50road miles on it and the inner seal is leaking, i am thinking maybe i did something wrong, the seal was not leaking when i replaced it, i replaced everything while i had everything tore down going thru replacing all wear item parts , i do have an old auto repair manual with an exploded view of the rear end, however , does not give me a step by step, i am thinking that i can jack up the driver's side enough that i do not have drain the gear oil?
thanks
