MP Spring perches are actually OEM Dakota pieces.
The 5/8" pilot hole in the perch is a non-issue because the housing is also located off the 1/2" hole in the shock plate.
If you are worried about the perch pilot hole, a lock washer under the head of the spring center bolt works as a bushing.
