Thanks man. I'll ask the old man to check it out once it is out of the shop. I asked the previous owner but he said he looked on the side and there were no numbers.
What years are better then others?
Depends on what you mean by better , what part ? The block , the entire engine itself ??? Blocks are basically all the same , HP doesn't make a difference when it comes to blocks , just some of theparts that were used , depending on the year , HP vs NON HP .
As said , Thanks for your service .....
