I went out to measure for my Dana 60 today and I just want to see if im in the same range as others. I have 15x10 wheels with 3.5" of backspace on a 28x12.5 ET street. I shoved the tires up in the wells as far as possible, and tried to center them in the wheelwells and make sure they weren't sticking out front or back. I measured in a couple of spots from inside flange to inside flange of each wheel, and I came up with 49" each time. I just want to make sure im in the same ballpark as others with a similar setup before I go ahead and call up Cass to order my axles. This was done in the garage, not at a professional chassis shop, so im hoping im close to the average.
Please share what your overall axle lengths were if possible...thank you!
Matthew
