I can live with a $600-800 dollar trans going out. Having to repair twisted quarter panels could really bunk me out.
What you need to know is if you lose the driveshaft or blow the rear you MUST pull the trans and check the sprag.
Don't treat it like your 2X cam lobe eating fiasco because if you don't do it the front drum can EXPLODE and guess where it's going ....
