I appreciate the kind words. But there are lots of guys who can do same things I do...10.0's out of a SB these days is not that difficult in typical A body.
Depending on vehicle weight & efficiency you'll need to be in the low 600's HP wise to get there in a typical bracket setup. The car has alot to do with the ET. I've had 610 HP motors run in the 9.70's @ 3100 LBS & I've had 675 HP motors off same dyno run 9.80's @ 3200 LBS... you can figure out which chassis setup/coverter etc worked better. HP is'nt everything when it comes to building a quick car.
Thanks for the info, could you do it using a 360/380 hp magnum crate motor with the iron heads ?
71 Demon
