How much power would you say could be made with a set of CNC ported HEMI Stage V heads, 4,5 bore block, 4,375" stroke crank?
This would be pump gas and naturally aspirated.
I also have 2,25" headers.
I dont have the heads but was thinking about the replacement stle Stage V HEMI Heads. I know they make some other more serious heads but then you have ti use custom headers and more expensive rockers I think which would go beyond my budget...
With a very mild roller (under 600 lift), 10.5 comp, Stage V intake with two 650 carbs, and CNC ported Stage V heads, I got 658 at 6500rpm. 472CID
