For that distributor you can go with the Pertronix II or the III
The difference between them is the III has dual strike through the entire RPM range, RPM rev limiter and I think it 45K volts.
Make sure you get the matching coil, the II and II use different coils.
Easy install, solder a wire across the back of the ballast resistor (not required with pertronix) and everything looks stock
Choice is yours, less work for the pertronix conversion.
thanks for the reply. i think that's what i'll do.
unions....the folks who brought you the weekend!
