Thanks for the replies. I talked to a engine computer repair shop and they were pretty adimant it is the PCM now here is the part that I don't get. the tech said it was caused by the battery being out of "parameters" and that caused the ROM to fail. Said I had to start it with a diffrent battery after replacing the PCM or I would have the same problem again? So am i to believe that on these newer cars with computers controling everything that if your battery is "weak" you are going to damage one of the computers? I find it hard to believe that these systems are that sensitive.
Well I have a new PCM on the way and I will take a known good battery and put it in the car just in case but the battery just dosen't make a lot of sence to me. I have had no traditinal signs of the battery going bad.
