Got an engine from a guy (with a car I bought) that was already assembled as a short block. I took everything apart and things seem fine, including clearances. One question on the rings though; both the 1st and 2nd compression rings are the same. I didn't know that they did that. They both have a bezel on the inside top of the ring. They both have one dot (dimple) on the top as well. I thought the second ring usually had a bezel on the bottom?
Thoughts?
