Re: 4bbl vs six pack
[Re: DPelletier]
#933348
02/22/11 10:36 PM
02/22/11 10:36 PM
Posts: 21,318 Manitoba, Canada
DaytonaTurbo
Manitoba, Canada
Yes, the observations that the 6 pack is pricier is true. OTOH, the whole "you'll make more power with a 4bbl" thing; maybe, maybe not...it all depends on the motor, which aftermarket manifold and what you mean by "more power".
Read the first article I linked, I really like it because the tests were done at around 450hp which is very realistic for alot of enthusiasts. This is the only comprehensive dyno test of the various mopar manifolds that I'm aware of. My only gripe is that they didn't test a stock cast iron 4bbl intake and carb.
For those who can't be bothered to read it;
Offy dual port - 412hp/436ft lbs offy dual quad - 425/431 Edelbrock performer - 439/455 Weiand Team G - 442/437 Weiand Action Plus - 442/452 Eddy DP4B - 445/456 Mopar 6 Pack - 450/459 Eddy Performer RPM - 451/457 Eddy TM6 - 452/449 Weiand Tunnel Ram - 453/455 Holley Street Dominator - 455/449 Mopar M1 and Eddy Victor - 456/449 Edelbrock Torker - 457/456
...As you can see the 6 pack (on this setup, anyway) is within 7hp of the best aftermarket setup tested but has the highest peak torque of all of them. 3 of them give up 10 ft lbs to get 2-6 hp more which is no win. The tunnel ram; well, it's a tunnel ram and few people want to have thier carbs sticking through thier hood so that leaves the torker and the RPM as the only real equals.......not bad considering the 6 Pack is a stock setup.
At this power level, IMO the DP4B is the better choice than the RPM. The rpm gives up a small amount of torq down low because it's ports are needlessly large for a a guy running stock/unported or only mildly touched up stock heads. The DP4B looks like a stock intake and only gives up 5hp at peak rpm to the RPM intake but makes more down low. You're always looking for the bottleneck, and so long as you run stock heads, any 1/2 decent aftermarket intake is NOT where the flow bottleneck is. At least with the DP (ch4b if you're doing a 440) you don't have the hood clearance issues, etc.
