The Cuda now has a 10.53 ET best with a bunch of 10.54s and 10.55s. The prior best was 10.62 in much better air. The car has Cal-Tracs Monoleafs and Caltrak bars set on the top hole . We started the shock settings at full loose on the extension and 7 clicks stiff on the compression. The car seemed to like it and since it was a bracket race, we didnt make any adjustments. We are very happy with the 1.37-1.38 times out of the little tires and good shocks.
