Even the crank indexed to the keyway can be out.
Just slam the production stuff together but if you find yourself asking if it should be checked. Then it should be checked.
That's why you check TDC to the damper mark, and you can time the engine correctly after correcting the alignment of the timing tab O mark.
logan426
