I went through this last mounth
did not want to pull the heads
got 2nd set of springs and went with a single with damper that droped on with stock seals and no machine work to the head
machine shop said pc seals?,and machine work to valve guide and spring seats with the lunati double springs and damper
I just matched the spring rate and its good for my roller cam so far,6200 rpm
