I need a 048 radiator for a 68 I just acquired and just found a 054 that is available and for a 69, the 054 has fittings on the bottom tank for the internal trans cooler.
My question is: The 048 radiator, do you know if these are suppossed have fittings on the lower tank like the 054 radiator? My 68 has an auto and has the external cooler mounted in front of the radiator, the rad in my car right now is from a 70 383-440 and I want to put it back to the original Hemi Radiator.
Car is enroute so I can't tell you what my rad looks like other then the car has been driven with it for a couple of years now.
I was figuring on having the 054 redone to original specs and see if I could do a trade for a correct 048 which I need for my car.
Thanks Folks,
Gibby
